is the rate of data logging from pixhawk fixed?, if not how to make it fixed for data analysis purpose?
Can you specify which message you want the rate change ?
Each message can be in a different rate parameter.
You can search for “stream” in QGroundControl parameters list, to check all parameters and ardusub code to check the parameter-message map.
