Ping360 Firmware Update
Hi Folks,
The Ping360 Scanning Sonar just got a performance boost. All new units now ship with updated firmware that improves scan rate across all interfaces and adds support for the auto_transmit function. See the comparison below vs the old firmware.
If you already have a Ping360, you can update the firmware using Ping Viewer (version 2.6.0 or later). Follow the update instructions here.
A couple other quick updates:
  • The Ping360 now uses a new cable with a larger diameter and heavier-gauge conductors.
  • The WetLink Penetrator has changed from M10-4.5-LC to M10-5.5-LC to match the new cable.
Daniel how do you get to the firmware update menu?
Hi @Diveright -
Welcome to the forums!
You find this menu in the PingViewer interface, with the sonar connected via USB/Serial directly to the computer you’re using. Checkout the documentation that Daniel linked above?
