Ping360 Sonar – Unable to Receive Data (Technical Review and Questions)
Hi @beyza,
I’ve fixed the formatting in your post, so it’s easier to read/follow. If you want to create posts/comments using markdown formatting then you can change back to that (from the default “what you see is what you get” editor) by clicking the slider in the top left corner of the editor:
Screenshot 2025-11-23 at 9.02.26 am
Indeed. As covered in the FAQ on the product page:
That’s unlikely, because the initial transmission generally has a period of ringing resonance at the start, which normally needs to be filtered out, but should be above your threshold level.
That said, from a quick reference to the relevant protocol message, it seems you’re not following the specification. You have apparently made up a _start_bin variable in the place of the transmit variable, and setting that value to 0 means the sonar doesn’t transmit, so it doesn’t return any data (which matches what you’re seeing). You’re also inputting your _full_data_length variable to a message field that’s intended to be reserved. That may do nothing, but could also cause problems if the sonar interprets it some way you’re not expecting.
If it’s returning data, and it’s not uniform from the middle to the edge (which would indicate the transducer is not actually connected), then it’s real sonar data.
I believe the return plot is always unmodified.
The waterfall plot has some minor processing options (e.g. smoothing/antialiasing of the displayed data), which you can enable/disable in the display settings. It also applies a selectable colour map to help visualise the different levels of return strength, but other than that the data is as raw as the sonar sends it.
That’s highly dependent on what you’re trying to scan, but for initial “is the sonar responding” testing you can use the built-in example.
For more general scanning, it may be helpful to see what Ping Viewer does. If you have a specific setup in mind, you can also get the data looking nice in Ping Viewer then turn on debug mode (from the display settings) and copy the transmit parameters from there.
Partly covered in 2. Beyond that,
There are understandably also more sophisticated obstacle detection approaches than thresholding of individual profiles. As an example, you could consider spatially grouping nearby detections as “objects” that could then be tracked through space (possibly with an estimation algorithm, if it seems like they’re moving).
The serial and ethernet communications interfaces are functionally equivalent, but ethernet is faster, so profiles return with lower latency, and the scans can be faster (especially at short scanning ranges). This was extra important before the 3.3.8 auto_transmit firmware update was available, because the manual transducer control approach requires communication both ways at every angle.
Serial may be able to transmit further in some situations (via RS-485), and requires less hardware to integrate, but if your Ping360 is staying relatively close to the device you’re attaching it to, and you have the budget for an ethernet switch, then the ethernet interface can provide some improvements.
Note that when used on a vehicle the serial connection needs to communicate through the onboard computer, whereas the ethernet connection is just available on the network, so if you just want to talk to the sonar from the topside then it’s possible to do so without involving the onboard computer’s processor and communication hardware.
See 3.
UDP is the transport layer communication protocol used when the Ping360 is connected via its (physical) ethernet communication interface - they are two parts of the same connection.
