Ping2 data from telemetry logs?
Hi - I use a BlueRov2 with a Ping2. I’ve reviewed the QGC telemetry csv log and there seems to be ping2 data logged in the field called ‘rangeFinderDist’. Am I correct that this is distance between the machine and the seabed? I see there is a great deal of effort in extracting data from the PingView bin files (eg Retrieve Ping Sonar data for analysis) - does this provide a different distance measurement to that available in the telemetry csv file? Thanks.
Hi @Paul1 -
The effort to extract the data from Ping Viewer logs does return he same value as what is logged in the .BIN autopilot log, which I believe is what you’re also finding in QGC logs. The autopilot log is often easiest to deal with, but if you’re using a vehicle with GPS lock there is an extension that may be preferable!
