My question is simple: is it possible to record the sonar ping data along with the video and telemetry data for later processing ?
Hi @Alex_J!
Partly, depending on what you mean by “ping data” and the format you want it in.
Cockpit can log telemetry on a configurable interval and tie it to a video recording. When a recording finishes, it generates a subtitle (.ass) file containing the logged values, sliced to match the video’s timeline. That subtitle file downloads alongside the video from the Video Library, and you can overlay/burn it into the footage afterwards (e.g. with HandBrake) or parse it for post-processing.
So if you just need the distance/altitude value from the Ping1D: as long as that reading is reaching Cockpit (e.g. forwarded to the autopilot as a rangefinder/DISTANCE_SENSOR MAVLink message), you can add it to the telemetry overlay configuration and it will be logged and exported with your video.
Setup steps are in the docs:
A couple of important caveats:
.ass subtitle file generated when a recording completes — there’s no separate “export raw telemetry log” option today. I have opened a draft PR for that and I will be opening it to be reviewed and merged during the course of this week, as its a feature that is on our roadmap for this month.Let us know if you have any further questions on how to setup everything.
Thanks for the answer.
I was hopping to record the full waveform, so maybe ping viewer will be my only option, but it’s not as user friendly as other telemetry.
I will check how to do.
Bye
Hi @Alex_J -
To clarify - pingviewer next is different than ping viewer! The former is a new BlueOS extension, the latter is the older, standalone application for communicating with Blue Robotics Ping sonar devices…
