I also cannot see Ping1D Echosounder values in QGC.
I have:
Companion Computer Firmware v0.0.20
ArduSub v3.6.0 dev
QGC v.4.0.8
I can view Ping Echosounder measurements using Ping Viewer 2.1.0 just fine.
I have tried every option mentioned in this thread with no success, to view Ping Echosounder values on QGC.
Since there are multiple range finders (RNG defined RNGFNDR1-9 and RNGFNDRA, which one should I configure as MAVLink and which variable to select from QGC interface parameters?
Could you please share the parameter settings of ArduSub for displaying Ping Echosounder measurements in QGC v4.0.8?
Depth hold (depth being the distance from the surface to the ROV) relies on a barometer, I assume you’re referring to altitude hold (altitude being the distance from the ROV to the seafloor). I’m in the process of testing altitude hold with a Ping1D myself, but as I’ve understood from the reverted commit linked below, the behavior from the Ping1D locking onto reflections is a bit erratic. Depending on how susceptible your use situation is to reflections this may or may not be problematic. Sub: Remove rangefinder support of control loops · ArduPilot/ardupilot@4b16271 · GitHub
Check the 0.0.21 companion update post. I advise you to use Ardusub 4.0 to get that working (the integration script doesn’t work with older versions to avoid the erroneous altitute-hold behavior).
Hi @williangalvani so is it possible to use the Ping1D to follow the terrain now? so Alt Hold instead of Depth Hold? if so what parameters need to be changed to turn this feature on? we get alot of requests for this feature.
not sure if the Ping 1D would work for that since the beam is quite wide it picks up a lot of things and gives false reading. (from my experience)
I could easily modify the expanse software to use out6,7 to connect to the ping and get the data out to the OV-Rec overlay if this is of any value. let me know.
