I have a 2 pontoon boat used for soundings, T200 thruster on each pontoon. Separate receiver for each pontoon/thruster.
Power switch on my RCU gave out. old RCU is FrSky taranis Q7 (ACCST) I’m looking at replacing with FrSky (ACCESS)RCU.
I have never setup an RCU, Looking for guidance.
Hi @RobHarr -
Generally Blue Robotics doesn’t have much experience with remote control transmitter setup, as all Blue Robotics vehicles rely on a computer with attached gamepad!
I’d recommend following the instructions that your replacement transmitter comes with. It’s a bit weird to have two receiver units - I would expect it would be easier to only use one, and run the signal from hull to the other hull’s ESC. It may be a struggle to pair two receivers at once!
It’s also worth noting that T200s are not well suited to boats - the nozzle on them makes them efficient at low speeds, for high force. An M200 with weedless prop will move your vehicle much faster, and more efficiently!
