Hi @Runwil -
The issue is that you enabled the streams in the DWE extension. Note that our instructions do not even mention this DWE OS extension! That extension is only used for adjusting the bitrate… if you disable the streams with those two switches, they should show up in the BlueOS Video Streams page and all work normally!
Here is from blueos video stream page. As seen, both camera are green/online. And if i fetch a thumbnail, picture from cams show up. But no live streams.
Hi @Runwil -
Ah - another easy mistake to fix! MJPG is not supported - delete both of those streams with the red trash-can icon, and add streams for the other video devices that list the format as H264. You’ll then be all set!
