I have a Low-Light Analog Camera, but have lost the ‘3-pin video connector’ cable that came with it. What type of connector/cable do I need to purchase that will fit the camera’s connector?
Hi @AlekC We have our own proprietary cable we made for the Analog Camera that was designed to connect to the Fathom-S board. You can contact sales@bluerobotics.com if you would like to buy one.
There is a 3-position JST-ZH on one side that connects to the camera and a 3-position 0.1" Female Header connector that plugs into the Fathom-S board.
Hi Kevin,
Thanks for the quick reply. To clarify, the 3-position JST-HZ header on the camera needs a proprietary cable? I am planning on splicing the yellow video wire to composite RCA, so I don’t need the interface for the fathom-s board.
Sorry, to clarify what I mean by proprietary is that it is our design and what we make. Nobody else makes this JST-ZH to header pin cable besides us.
You are more than welcome to make your own cable with a JST- ZH connector, just mind the power polarity.
Hi guys,
I was wondering if it is possible to connect the analog camera directly to the raspberry pi?
Edit after some more research:
Analog camera to Fathom S to Pixhawk Telemetry Port (Fathom-S Usage Guide)
Does the video feed make it to the Pi?
Cheers ![]()
Hey I have a problem with this Camera model , I tried to use it several times but it simply dosen’t work I see nothing on the monitor after I connect it.
Red: 12V supply
Black: GND
Yellow: Signal Video input in the monitor
I tried everything but It’s not working.
Thanks ^^
Please share a picture with your setup and all your connections.
Your camera and monitor also need of both the same format to be compatible ( NTSC or PAL).
