Hello, good afternoon!
I am experiencing an issue with my ROV using ArduSub and Cockpit, and I would appreciate your help in identifying the cause.
Problem Description
When I arm the ROV using Cockpit, both vertical thrusters start spinning continuously, even when I am not moving the joystick. The vehicle is configured in MANUAL flight mode.
This behavior is unusual because when using QGroundControl, the system works normally. Therefore, I suspect there may be a difference in Cockpit’s configuration, command mapping, or communication with ArduSub.
Checks and troubleshooting steps already performed:
I confirmed that the joystick is working correctly and that all axes respond normally in the Visual tab of the joystick configuration.
I checked the joystick mapping and configuration options in Cockpit.
I verified the vehicle type selection, including the
MAV_TYPE_SUBMARINEoption. -
I confirmed that the issue occurs while operating in MANUAL mode.
I considered whether sensor calibration or any depth-control-related configuration could be involved.
I compared the behavior with QGroundControl, where the ROV operates normally.
So far, I have not been able to identify the cause or resolve the issue.
I would like to clarify the following:
Is there any specific Cockpit setting that could cause the vertical thrusters to receive continuous commands as soon as the ROV is armed?
Are there any differences in command mapping or in how Cockpit handles signals sent to ArduSub compared with QGroundControl?
Which parameters, telemetry messages, or logs would you recommend checking to identify the source of these unintended thruster commands?
Is there a recommended troubleshooting procedure to test or correct this behavior without unnecessarily changing the ArduSub configuration?
I can provide screenshots of the Cockpit configuration, as well as any additional information, parameters, or logs needed to assist with the diagnosis.
Best regards,
