Is it possible to install BlueOS on Jetson Orin?
Hello everyone,
I plan to use NVIDIA Jetson Orin instead of Raspberry Pi for my ROV setup.
I have a quick question about the setup process:
Flashable Image: Is there a ready-to-use .img file for Jetson devices (similar to the Raspberry Pi version) that I can easily flash to an SD card?
Installation: If there is no direct image, is it possible to install BlueOS? What steps should I follow for this?
Compatibility: If I can perform the installation, are BlueOS’s core functions currently running stably on Jetson hardware?
Thank you for your help.
Hi @omer_1,
Nope - we only automatically build Raspberry Pi OS images.
There is an install script, which may work for your board. There is some potentially relevant discussion in this thread, and we can try to help resolve issues you run into if it doesn’t work :slight_smile:
Not sure - it’s not something we have ready access to or regular/comprehensive testing on.
To add on that, BlueOS has some support to Jetson, the best method to have it running is following the instructions here:
