How to Calculate for Damping Coefficients
I am running some simulations on various ROVs including the BlueROV2 in MATLAB and in Gazebo. The model I am basing my approach on is Fossen’s Marine Craft model.
For this model to work, one of the properties I need is the linear and quadratic damping coefficients for each of the six (6) degrees of freedom of the ROVs (i.e. surge, sway, heave, roll, pitch, yaw). For quadratic damping, I am using the drag equation below:
F_d = \frac{1}{2}\rho c_d A u_{x}^{2} \\ where: \ X_{uu} = \frac{1}{2}\rho c_d A
This is done for each degree of freedom. I am currently experimenting with using the default C_d value for cubes and cuboids (i.e. 1.05), and deriving a C_d using SolidWorks Flow simulation.
For linear damping however, I am unable to find any equation or method of deriving its drag coefficient. The closest thing I have seen from research is using Stokes Drag equation for tiny spherical objects at low speeds, which ROVs are not.
I want to know how the linear drag coefficients are determined for the BlueROV2 and other ROVs. I am okay with either using an approximation, CFD with SolidWorks Flow Simulation, or experimentation. Also correct me if I am wrong on the calculation of quadratic drag.
