GPS signals to QGC
Not that I’m aware of, you can search/add a feature request in QGC: Issues · mavlink/qgroundcontrol · GitHub
Many thanks, Jacob.
Hi Oystein,
I am trying to get my GPS data displayed on QGC and am wondering what you finally did to get the LAT/LONG to show on the display. I have tried sending it to UDP 27000, but no luck. Would very much appreciate it if you could tell me how you did it.
Thanks,
David
Are you using a USBL, WaterLinked or just surface GPS?
I followed a procedure that Jacob explained to me. I believe I made a “how too” procedure with text and figures. I used a free software called nmea router. I Will look for the procedure
Hi All,
Thank you for responding. I used NMEA Router too. Rusty at Blue Robotics told me I should just try disabling GPS in the QGroundControl setup because is was somehow conflicting with NMEA Router. I did it and it worked. I just sent it to UDP 27000. That’s it.
Best regards,
David
I know its an old post , but how do you disable GPS in the QGC
Hi @Mac1
Maybee to many places, but better safe then sorry (numbers 1-3 refering to picture):
  1. Turn of RTK GPS
  2. Turn of connected NMEA
  3. Turn of connections in Commlinks
  4. Do not send NMEA to QGC other then thru Companion 192.168.2.2:27000
