Having problems with NMEA out - see above - any suggestions?
Setup is:
Simrad hs60 to actisense nmea2000/0183 gateway/usb serial converter into PC com6.
Waterlinked GPS2 and blueROV into fathom x tether interface into PC.
PC runs NMEA bridge, but input flashes red with ‘TIROT’ and ‘HDHDG’ not supported
and “HDT and THS recieved - can give jumpy orientation”
How do I get the NMEA bridge output back to the waterlinked box? and remove the errors from the input?
Thanks…
Drawing below…
