Frame in ardusub
Hi,when i want to develop a new motor configurations,i raed the ardusub code.I find a frame named VECTORED_6DOF_90DEG.So i am very curius about that.
Can you tell me how are the motors of this frame arranged?
Hi @octopus,
It’s possible to determine a the motor arrangement using the thrust factors in the table so let’s do so:
  • In this case all the numbers have magnitude either 1 or 0, so the thrusters must be symmetric / at equal angles.
  • Motors 1, 3, 6, and 8 are facing upwards (they have vertical but no horizontal components), but also have roll and pitch components so they are at the corners rather than being stacked vertically in the middle
    • This is like the vertical motors in the BlueROV2 Heavy configuration
  • Motors 2 and 7 have only yaw and forwards contributions, so will be oriented along the horizontal plane, and spaced out towards the sides and facing either directly forwards or tilted slightly inwards or outwards from the central travel line of the vehicle
  • Motors 4 and 5 have only lateral contributions, with no yaw, so will be in the horizontal plane and collinear with each other and pointing at the centre of the vehicle
This is roughly equivalent to a BlueROV2 Heavy configuration but with the horizontal motors oriented at 90 degree angles relative to the vehicle, rather than being tilted. On a drawing it could look something like
Could you explain how the Roll, pitch, yaw, throttle, forward, and lateral factors are calculated for FRAME - BLUEROV1?
I designed and built an open-frame ROV with six thrusters. What will be the Roll, pitch, yaw, throttle, forward, and lateral factors? If you could help.
Thruster 5 and 6 is vertically below thruster 3 and 4.
Hi @mnpmilan,
This comment may be a good starting point for your understanding of thruster contribution factors, and this one covers some specifics of the BlueROV1 frame.
From your picture, at a high level your 1/2/3/4 thrusters contribute to vertical, pitch, and roll motion, so should have non-zero factors for those, and your 5/6 contribute to forward and yaw motion. You don’t have any lateral control authority. The actual numbers depend on the mass, volume, and thrust distribution of the vehicle.
What about the +ve and -ve sign? How are they calculated? any clockwise or ccw roation direction?
As far as I can tell (just looking at the existing frame factors), the positive sign convention for the motor contribution factors is:
  • Roll: right side down
  • Pitch: nose up
  • Yaw: nose to the right
  • Throttle (vertical / heave): up
  • Forward (surge): forward
  • Lateral (sway): right
Aside from the posts I already directed you to:
I don’t believe there’s a specific convention here - the idea is just to have counter rotation between opposing pairs of thrusters (e.g. all the greens should have one propellor orientation and rotate a particular way to generate thrust in the desired direction, and all the blues should rotate the other way).
