i have installed the ultimate beta release of blues, cause i’m using a Rpi4. So, this happened when i connected the Rpi via eth to the computer and opened the blueos page through its gateway ip:
Hi @nareloliveira -
It seems as if you may not be connected to BlueOS - perhaps the Pi is still starting up. Can you ping the IP address? You may want to try clearing your browser cache as well.
Solved
. I was expecting the PX to communicate with the RPi5 via the SPI socket, but it turns out BlueOS uses the USB port instead. The real issue was “between the chair and the laptop.” ![]()
