Current cause rov swinging
Bluerov2, current at about 8-10m deep, gain 25% will be pull back, gain 50% could move ahead slowly. Rov swings while moving around in stablize mode. Is it normal or I need to calibrate the pixhawk?
Ooyama,
It’s normal to require a bit higher gain in strong current situations. The 25% setting is best in very calm conditions. What do you mean the ROV swings around in stabilize mode? Is it rolling? Is the heading changing?
