Hi
Is is possible to create a disk image of the SD card with BlueOS fully configured. In Linux, the ‘dd’ command is used. Can I still use this command and how do I get at it?
Cheers
Jason
Hi @scriffij, what’s the context here?
There are two relevant options I can think of:
- We provide pre-built BlueOS images in the GitHub releases
- Download
BlueOS-raspberry.zipfrom the Assets of the relevant release, and flash it onto an SD card
- Download
- If you’ve made your own configuration that you’re wanting to turn into an image then
ddis the appropriate command, and you can run it from either- the Terminal page in BlueOS
- You’ll need Pirate Mode turned on to see the Terminal page
- Terminal starts out inside the BlueOS-core docker container, so you’ll need to run the
red-pillcommand to drop down into the underlying Raspberry Pi OS beforeddmakes sense to run - If you generate/move your image to
/usr/blueos/userdatathen you’ll be able to download it using the BlueOS File Browser
- Alternatively if you prefer to just use your computer’s terminal with command-line programs, you could connect to BlueOS using
ssh, then runddas desired, and fetch/send the resulting image usingscp
Feel free to clarify if that’s not what you’re asking about ![]()
