[When reporting issues, please post the product, a description of the issue, code if it’s a software issue, and pictures of the issue. That will help us resolve it quickly!]
Hi!
While trying to charge my batteries I had an error on the charger “Ext. TEMP OVER CHG STOPPED” as per the mannual is “The external temperature sensor detects (battery) temperature above the limit”. I tried to charge the batteries with a second charger and is charging normal with the same batteries. Any ideas what to do?
That’s odd considering that the charger has no input for battery temperature monitoring. Please email us at support@bluerobotics.com so we can figure this out, its possible your charger has stopped working properly.
Thats correct. The problem just suddenly ocurred. Adam sorted it out, just needed to go ahead into the settings and turn the Temperature Cut-Off to off.
