Hi, can anyone help with this battery charging error message on the charger
Ext. TEMP OVER BREAK DOWN
Hi @Ronnie,
Are you operating the charger in an elevated temperature, or are the fans/intakes blocked or not spinning?
-Adam
Hi Adam, ambient temperature is 16 degrees centigrade
The forward/smaller fan runs for around one second when the power is switched on, otherwise no the fans do not run
Hi @Ronnie,
It sounds like your charger may be defective, please contact support@bluerobotics.com with the information you have relayed here as well as your order number.
-Adam
