Hi all !
I have a question: Do you think the BR2 standard is able to support a slr camera in its case ?
Or do you think i must change to the heavy configuration ?
Hi all !
Hi @bdevis,
If you can mount the camera under the ROV and keep it centered well under the center of gravity, then I think it would do pretty well on the standard ROV. I do think there would be some “swinging” when the ROV moves forward or the tether gets pulled.
That would be fixed with the Heavy Configuration and you’d get much more stable shots, especially if you’ll be filming video from the camera.
Hi @rjehangir,
Ok I’ll test the standard solution and I will give a feedback to the community.
The SLR used will be a canon 5Ds.
