Please have a look at the attached images. I want to attach this beacon to my ROV I was thinking of drilling one of the rear buoyancy modules so the beacon could sit partially in the module but then I would not able to rely on the beacon just sitting in the module as it would be disappear in no time subsea.
Its a fairly awkward shape as the beacons are normally longer and easier to attach. I am open to ideas.
I was thinking about doing the same only in the fwd casing. I have the X110 as well. I ended up with an improvised solution for now but I believe I will stick to it, just make it a bit more professional looking. Mind you that my solution is for inspection works only and not for “working” and bumping into structures. I will post a picture later
The software can be downloaded from the internet. A new updated software is soon to be released as well.
The price for the X150+X010 including the deck cable and usb gps is approx 8kGBP ex vat. as far as I remember. That is the setup I use
Have you manage to get the Lat/Long coordinates to show up in Qgroundcontrol on the overlay as you fly the ROV?
If so, I am interested in how you manage to do it?
