Hello
I have update to new ArduSub v4.5.3 now the relay is not working anymore.
Relay is working with Cockpit v1.12.2 ,BlueOS v1.3.1 and ArduSub v4.1.1
I have also tried ArduSub v4.5.0,but is not working ?
Hello
Hi @an-ron,
Our documentation on this is definitely lacking. ArduSub 4.5 introduces some different parameters for managing servo outputs and relay options, so to configure a particular relay you’ll need to set:
| Parameter | Value |
RELAY*_PIN |
output channel number (e.g. AUXOUT1 (50) for Pixhawk Aux 1; Navigator just uses the servo output numbers directly) |
RELAY*_FUNCTION |
Relay (1) |
RELAY*_DEFAULT |
As preferred |
SERVOn_FUNCTION |
GPIO (-1)Note: “ n” is the selected output channel number for the relay (e.g. 9 for Pixhawk AUX 1 (factoring in the 8 MAIN pins), or the pin number for Navigator) |
For clarity, the old BRD_PWM_COUNT parameter no longer exists, and the old RELAY_PIN* parameters (where * is a number) have been renamed to RELAY*_PIN for consistency with other similar parameters.
Hi @an-ron -
That relay you’re using requires a 5V control signal, and the Navigator only provides 3.3V! It is never going to work as a result…
You can verify you’re switching the output from 0 to 3.3V with a multimeter, I’d expect it is working fine! (Do this with your relay disconnected.)
There are definitely relays that can be controlled via a 3.3V signal, like this one. Keep in mind the amount of mA the Navigator can provide is fairly low - check the Technical Details
Technical Details on the product page for more info.
Now I don’t understand,you misunderstand me.
I have use these relays in ArduSub v4.1.1 with Navigator and i working.
yes,requires a 5V control signal same as a Servo.
I’ve just tested this and the relay configuration on 4.5.3 seems to work fine for me.
I tried pins 9 and 14, and both showed up with the expected 1/0 values in the corresponding SERVO_OUTPUT_RAW values in MAVLink[1]
and also both output 3.3V on the relevant pin as expected (verified with a multimeter).
The SERVOn_FUNCTION parameters didn’t seem to make a difference (relay seems to just ignore and override whatever is configured), so I just left it as GPIO to be more clear for future modifications.
Some potential causes for the issue you’re running into:
+ servo rail then make sure there is power supplied to it (e.g. via the AUX 5V pin)SERVO_OUTPUT_RAW 1/0 vs multimeter voltage readingEvery component is different - you need to look at the specs of what you have.
There are many servo motors that can be powered with 5V (or a range of voltages) while still operating fine with (and being rated to use) 3.3V command signals.
I was testing with Cockpit’s Plotter widget, but you can also use your MAVLink inspector of choice ↩︎
now I went back to ArduSub v4.1.1 and everything works.
There is nothing wrong with relay or power,relay is working with ArduSub v4.1.1.
There must be something in the settings that has been changed in ArduSub v4.5.3
I’ll try a little more and see.
Have now tested a little with ArduSub v4.5.3
When I choose Relay1_DEFAULT ON restart the Autopilot,the relay is coming ON and same procedure again only with OFF, relay is coming OFF.
so relay is working but when i use button 15 to relay 1 toggle nothing happens.
I have tested these versions and none of them work with the button ![]()
4.1.2
4.5.0
4.5.1
4.5.2
4.5.3
Only versions 4.1.1 is working with relay 1 toggle button 15 ![]()
Hi @an-ron -
Sorry for the issue and my misunderstanding of the hardware previously working! Can you try just the Relay 1 On/ Off mapped to buttons, rather than toggle, and see if that makes any difference?
I have now try Relay 1 On/Off mapped to buttons 15 and is working ![]()
Something wrong with mapped toggle?
Hi @an-ron -
It would seem so! I’ve noticed similar behavior from the Arm toggle - we’ll dig into it and see about a fix moving forward. Thanks for your patience and understanding - I’m glad we found a workaround!
Then I only use 2 buttons instead of 1 button to activate relay,until you fix problems with toggle button.
Thank you very much for your help.
