I loaded the img file found in this link onto an SD card using Balena Etcher. Then I inserted the SD card into my Raspberry Pi 4 card and connected it to the monitor using an HDMI cable. When I powered up the Raspberry Pi card, it asked for a username and password as shown in the photo. What should I write in these sections?
Hi @beyza -
BlueOS is intended to be run headless, without a monitor plugged in! You can login with the default password there if you need access via the terminal (pi / raspberry) but the intended interface is to go to the Pi IP in your browser… 192.168.2.2, assuming you’ve set your interface to a static IP on the same subnet (or received a DHCP IP from BlueOS.)
