Hi @Kolappan ,
You can use the code below for reading the message that you’ve requested:
def get_requested_data(master, message_name: str, dict_key: str, value_unit: str, save_name: str):
try:
message_index = 0
dict1 = master.recv_match(type= message_name, blocking=True, timeout=0.1).to_dict()
dict_value = dict1[dict_key]
toWrite = "Message_Index, " + message_index + " :" + str(dict_value) + value_unit
with open(save_name, 'a') as file:
file.write(toWrite)
file.write('\n')
message_index += 1
except:
pass
If you just want to monitor the data on Terminal instead of saving it to a file, you can go with deleting the lines below and simply use a print function:
file.write(toWrite)
file.write('\n')
message_index += 1
And here is the example usage of the loop code:
request_message_interval(master, "VFR_HUD", 1)
while True:
try:
get_requested_data(master, "VFR_HUD", 'alt', "m", save_name)
except:
pass
