3d printable intake guards for T100 and T200 thrusters
Here is a 3d printable front, and eventually rear intake guard for use with Blue robotics thrusters. It mounts underneith the stock nosecone, using two slightly longer M3 stainless bolts. This is an Open source CC by SA - Attribution project, so you may freely download, share, print and even sell the resulting guards if you like.
Project files and printable STL’s are there, this one prints well in ABS and takes a massive amount of support material to print, but the end result is quite strong. Please be aware that this WILL reduce your available thrust and top speed, and is only intended for locations where an intake blockage is likely.
The rear guard will be designed to slip over the fixed back nozzle and mounts to my reinforced thruster mount brackets with two M3 bolts. It’s not quite done yet though.
Very cool, and nicely done! Can’t wait to print this and also see the reverse side.
-Jacob
Thanks! My plan is to finish the rear one later tonight. It was getting a bit warm in the printing room heh.
Awesome! Nice work. We’ll print one out and give it a shot too.
Very cool Tim! I will definitely want to implement something like this for my upcoming build. Did you try out Spallys version before designing your own? https://discuss.bluerobotics.com/t/seaweed-deflector/
No, he didn’t have the STL files anywhere I could find them so I decided to make my own.
Thanks! Let me know if it needs any changes.
Genial, estoy en proceso de comprar una impresora 3D para realizar este trabajo, tienes alguna recomendación en cuanto a impresoras?
Gran Trabajo Tim.
Regards.
my creality ender 3 is very good. There are some other recommendations in this forum: Advice on a 3D Printer
