Video Stream gets worse when light are turned on?
Hello!
I have successfully got control over a standard BlueROV setup via the internet using ‘ZeroTier’ software and the standard companion image.
I have noticed that when I turn on the lights the video stream starts to break apart and go grey.
If I turn the lights off the video stream returns back to normal.
Anyone else have the same problem?
Does anyone have a solution to fix this?
Thanks,
Adam
It sounds like u r losing power to the camera when lights r turned on. Check for bad connections n potential voltage drop at camera when lights on
