Vacuum testing and the vacuum tester failures
We use the mighty vac as well. We once had some trouble finding an air leak. We rented (for free) a vacuum pump, used to do Air Conditioning work, from Autozone that drew a vacuum so quickly that we were actually able to hear the leak and find that we were getting air through a wire sheath from a leaking external camera. The electric vac also can remove all of the water from the container by boiling it off.
