Acceptable vaccum test levels
Hello, I have been really struggling to pass the vacuum leak test for our newly purchased BlueROV2. I have re-made all the connections and sealings multiple times, changes all O-rings, but still, it seems that after the 15 minutes from 10 mmHG I get to at least 8, therefore not passing the suggested test.
Honestly, I don’t know what to do anymore, any clues if those levels are acceptable and what would be my next move or any tips and tricks to solve this?
Thanks a lot in advance
Emiliano
It shouldn’t move.
That said, I suggest you test the pump by itself. Sometime, the pump leaks…
Cheers,
Etienne
Thanks Mate,
Yes i did, I have tested vaccum on the Battery enclosure, and that works fine! So the pump seems to be fine, unfortunately…
I guess I will try one last time to undo all the penetrators and then, worst case I will contact bluerobotics support.
:frowning:
Thanks again
All the best
Emiliano
How are you testing it? Just the main bottle by itself? If your pump is good, you might try both bottles at the same time. I think I’ve seen the battery cable leak, but I was having a few issues at the time and I can’t recall if it really was the battery cable, or something else. Anyway, I’d try both bottles at the same time with the T and see what it does.
Hi @Emiliano,
Are you using the T connector to run the lines to test both the 3" and 4" enclosure at the same time as specified? The wires themselves are not sealed, air will move from one enclosure to the other if only one is tested at time.
-Adam
Thank you all!
I tried with T connector, much better, but still loosing a bit. Last try i lost 1.5 (from 10 to 8.5 aprox) in 20 mins. :frowning:
How bad is that?
Thanks again, Ill keep trying.
Cheers
Emiliano
I think you should try and but your ROV in a bath tub and apply positive pressure to detect a leak. You will need to get another pump.
Wouldn’t this cause the end caps to blow out and flood the electronics enclosures?
Depends on how much pressure you put…
The 4 inch enclosure is secured on the cradle. You can also put threaded bar on the outside on the top.
The idea is to pressurize it before you put it in the water.
Following up on this old post. We had a serious leak during a recent dive, and the issue ended up being a leaky thruster penetrator. The potting epoxy apparently didn’t adhere to the inner wall of the metal penetrator fitting, allowing water/air to pass through an annulus around the epoxy plug.
We located the leak by taping the battery end caps on, pressurizing the case with a bike pump, and spraying soapy water onto the penetrator fittings.
We tried unsuccessfully to seal the penetrator with more epoxy. We eventually had to replace the entire thruster with one from our spares kit.
We still have a very slow vacuum leak (possibly coming down inside the surface cable jacket) but no more water intrusion so far.
I wish there was a reliable way to seal inside the jackets of all the cables that penetrate the electronics enclosure. It seems like if any of those cables get nicked, water could potentially get in to the enclosure.
That is the downside of using hollow cables and penetrators. The only foolproof way to prevent leaks from nicked cables is with wet-connectors.
We put “snoop” a safe non corrosive soap solution on the connectors and joints inside the housings. Under vacuum the clear housing “inside” bubbles were obvious. In the opaque aluminum housings the leaks showed up as froth when reopened. Interesting the slow leaks were from air moving through the cables and wires as under the jacket and between the individual insulated wires and down the stranded copper wires. Some was outgassing from the desiccant and some components especially transformers . Popped open the top of an old tired ESD cap once. One trouble some leak was found by pulling a vacuum and dipping individual parts in coloured water to see which one was getting wet,
I know it’s been a few years, but I was wondering about this slow leak. I’m seeing a drop from 15 inHg to 7.5 over ~18 hours. Is the tether fully potted, or can it draw a slow leak through the cable?
Not sure about the potting question but I’m pretty sure the recommendation for a vaccum test is maintaining 10 inHg for 10-15mins with a drop of less than 1inHg being acceptable.
I think that holding 15 inHg for 18 hours would be unlikely anyway with the bluerobotics supplied (mityvac) pump since the hoses and connectors use only barb fitting.
Also I presume the battery and electronics enclosures achieve a positive air pressure when submerged where that pressure increases with depth. This should help protect against micro leaks assuming all o-ring seals and where they contact adjacent surfaces are not damaged/scratched etc.
Any gap greater than the width of an H20 molecule is really all that is required for water ingress so any o-ring should be covered in a thin film of the molly grease (as well as the locking inserts).
Hope someone corrects me if I’m wrong above as this is the test I always do before dives!
