nct
(Nun Culture Technology)
September 5, 2018, 12:57pm
1
Hello all,
We’re working on a ROV at the moment. We are planning to use a USB Camera Module. However, we don’t want to use the one in Bluerobotics. Do you have any other camera you can reccomend us? Also, can we use ANY camera module without facing issues (with Ardusub)?
Thank you.
Any camera that provides video in H264 via USB is compatible with the companion software layer.
pob747
(Jan Robert Fiksdal)
December 13, 2018, 1:09pm
3
Hi, I am trying to use the Kurokesu C1 USB camera and the video stream is working but I only get 1 fps in QGroundControl video view.
Here is the datasheet for the camera: https://www.kurokesu.com/uploads/datasheets/Kurokesu_C1.pdf
Can I change some settings to get this to work with 30 fps?
Cheers, Jan R
Take a look in http://192.168.2.2:2770/camera , you’ll be able to configure the camera to match the frame rate that you are looking for.
pob747
December 13, 2018, 1:21pm
5
Hi Patrick, I am looking at the settings for the camera and it looks okay and correct, but still it is only showing 1 fps.
Anything else I can try?
jwalser
(Jacob)
December 13, 2018, 2:53pm
6
Navigate to http://192.168.2.2::8088 , open a terminal, and enter this command:
ls /dev/video* | xargs -L1 v4l2-ctl --list-formats-ext --all --device
Let us know the output. It sounds like our software cannot support your camera at 30fps.
pob747
December 13, 2018, 4:28pm
7
Here is what I got:
Driver name : uvcvideo
Card type : KurokesuC1_SN000786
Bus info : usb-3f980000.usb-1.5
Driver version: 4.9.24
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Camera 1: ok)
Format Video Capture:
Width/Height : 1920/1080
Pixel Format : 'MJPG'
Field : None
Bytes per Line: 0
Size Image : 2073600
Colorspace : Unknown (00000000)
Flags :
Crop Capability Video Capture:
Bounds : Left 0, Top 0, Width 1920, Height 1080
Default : Left 0, Top 0, Width 1920, Height 1080
Pixel Aspect: 1/1
Selection: crop_default, Left 0, Top 0, Width 1920, Height 1080
Selection: crop_bounds, Left 0, Top 0, Width 1920, Height 1080
Streaming Parameters Video Capture:
Capabilities : timeperframe
Frames per second: 25.000 (25/1)
Read buffers : 0
brightness (int) : min=-64 max=64 step=1 default=-8193 value=0
contrast (int) : min=0 max=64 step=1 default=57343 value=32
saturation (int) : min=0 max=128 step=1 default=57343 value=64
hue (int) : min=-40 max=40 step=1 default=-8193 value=0
white_balance_temperature_auto (bool) : default=1 value=1
gamma (int) : min=72 max=500 step=1 default=57343 value=100
gain (int) : min=0 max=100 step=1 default=57343 value=0
power_line_frequency (menu) : min=0 max=2 default=2 value=2
white_balance_temperature (int) : min=2800 max=9300 step=1 default=57343 value=4600 flags=
inactive
sharpness (int) : min=0 max=6 step=1 default=57343 value=3
backlight_compensation (int) : min=0 max=2 step=1 default=57343 value=1
exposure_auto (menu) : min=0 max=3 default=0 value=3
exposure_absolute (int) : min=1 max=5000 step=1 default=156 value=156 flags=inacti
ve
exposure_auto_priority (bool) : default=0 value=1
inactive
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'MJPG' (compressed)
Size: Discrete 1920x1080
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.040s (25.000 fps)
Interval: Discrete 0.050s (20.000 fps)
Interval: Discrete 0.067s (15.000 fps)
Interval: Discrete 0.100s (10.000 fps)
Interval: Discrete 0.200s (5.000 fps)
Index : 1
Pixel Format: 'YUYV'
pob747
December 14, 2018, 3:24pm
8
Hi, is there anything I can change to make it work?
Cheers,
Jan R
Hi Jan,
Are you sure this is the full output ? Because there is no “H264” pixel format on it.
jwalser
(Jacob)
December 14, 2018, 4:06pm
10
@patrickelectric There is an error in my command on the v4l2 version running in the raspberry pi. I need to come with a better command.
jwalser
(Jacob)
December 14, 2018, 4:34pm
11
@pob747 try v4l2-ctl --list-formats-ext --all --device=1
To check if it’s possible to use the camera without configuration or any modification, check the following steps:
Go to http://192.168.2.2:8088 to access the companion terminal.
Check the connected devices with: v4l2-ctl --list-devices
# In this example you can see two cameras connected
# mmal service 16.1: The raspberry camera
# H264 USB Camera: The low light usb camera
mmal service 16.1 (platform:bcm2835-v4l2):
/dev/video2
H264 USB Camera (usb-3f980000.usb-1.2):
/dev/video0
/dev/video1
Take a look in the camera capabilities with: v4l2-ctl --list-formats-ext --device=/dev/videoX
Where X is the camera ID (0, 1, 2 …).
Let us know the output for each device.
pob747
December 14, 2018, 7:24pm
13
Hi, this is what I got:
First is video 0 next post is video 1
pi@raspberrypi:~ $ v4l2-ctl --list-devices
KurokesuC1_SN000786 (usb-3f980000.usb-1.5):
/dev/video0
/dev/video1
pi@raspberrypi:~ v4l2-ctl --list-formats-ext --device=/dev/videoX
Failed to open /dev/videoX: No such file or directory
pi@raspberrypi:~ v4l2-ctl --list-formats-ext --device=/dev/video0
Index : 0
Pixel Format: ‘MJPG’ (compressed)
Index : 1
pob747
December 14, 2018, 7:25pm
14
This is video 1:
pi@raspberrypi:~ $ v4l2-ctl --list-formats-ext --device=/dev/video1
Index : 0
Pixel Format: ‘H264’ (compressed)
jwalser
(Jacob)
December 14, 2018, 7:42pm
15
Can you show us what the options look like in the companion webpage for framerate?
pob747
December 14, 2018, 7:45pm
16
Hi, yes here it is:
! h264parse
! queue
! rtph264pay config-interval=10 pt=96
! udpsink host=192.168.2.100 port=5600
pob747
December 14, 2018, 7:49pm
17
I use a small program for testing my USB cameras, “H264 Preview v1.16” and if I switch on the H264 encoding in that program I get the same effect of showing video in 1 fps. The moment I turn it off it goes to show 30 Fps.
Can this information be helpful?
Jan R
jwalser
(Jacob)
December 14, 2018, 7:52pm
18
I need to see the framerate options in the dropdown please
pob747
19
Framrate settings in gStreamer is 1920x1080 at 30 fps
pob747
December 14, 2018, 7:53pm
20
Here it is:
30
25
20
15
10
5
