After checking the setting value on the BlueOS parameter (SRn), when looking at QGC’s Mavlink Inspector, the update cycle is not the cycle set in the parameter.
Is there anything I need to do, such as restarting, and launch in a specific order?
To get the stream rates to change, you have to go into QGC Application Settings > Mavlink and enable “All Streams Controlled By Vehicle Settings” , then reboot the flight controller.
Thank you
“reboot the flight controller” means reboot on BlueOS?
We tried to do so, but sometimes it works and sometimes it doesn’t.
Could you tell me how to reboot the flight controller correctly.
