Hi everyone,
I recently started encountering some performance issues with the thrusters on my BlueROV2, and I’m hoping to get some insights from the community. Here’s the situation:
During a recent dive, I noticed that one or two of the thrusters seemed to be outputting less thrust than usual. Specifically:
- Thruster 2 (starboard front) and Thruster 4 (port rear) don’t appear to be generating as much force as the others, causing a noticeable imbalance in movement.
- The drone tends to drift slightly to one side during forward motion, and roll stabilization feels off as well.
- I checked the wiring and connections, and everything looks solid at first glance.
I’ve already taken the following steps to troubleshoot:
- Calibrated the ESCs to ensure no settings were altered.
- Cleaned the thrusters to remove any debris or fouling.
- Tested each thruster individually using the QGroundControl joystick and noticed that they all spin, but the output doesn’t feel uniform.
Has anyone here encountered similar issues? Could this be related to worn bearings, ESC configuration, or motor degradation? I’m also curious if it’s possible to test and compare individual thruster performance more accurately.
If anyone can recommend additional diagnostic steps, replacement tableau parts to check, or potential fixes, I’d greatly appreciate it. I’m trying to get the ROV back in top condition for a deepwater project next month.
Thanks in advance for your help!
Regards
Emiliasen
