Hello . Trying to set ups the new model with 8 thrusters . after configure to a big platform .
I can not get a signal out on Channel 8 for thruster . Have tried to switch connector on 2 thrusters . And all work .
But it seems that the signal does not come out of port nr 8 . Any tips ?
Regards Danne
Check the parameter value of SERVO8_FUNCTION, it should be assigned to motor 8, you may have a conflicting assignment like the camera. Make sure the camera tilt is assigned to a different channel on the camera page. Or, you can load the parameter file contained in the heavy setup documentation: BlueROV2 Heavy Retrofit Assembly Tutorial
