Temperature of operation
What’s the temperature normal of operation of BlueRov2?
I’m getting critical temperature warnings, 58 ° C
Temperature can be considered normal for operation?
I’m university brazilian. I need help for a work of scientific initiation.
Hi @Piana The normal operating temperature of the BlueROV2 is somewhere around 60 degrees C internally. After 70 degrees C, the Raspberry Pi will start having over-heating issues and attempt to throttle its CPU. We have seen some video and connection issues with internal temperatures above 70C.
Does your ROV have an Internal Temperature parameter set? By default, Failsafe Actions for Internal Temperature are disabled.
Hello, my ROV did not have the temperature parameters configured, so I did the configuration, update the binaries and process limitation, I managed to solve the problem … Thanks !! Sorry for the delay to reply!
