T200 performance with relative speed
Hey,
I understand that the CVC file included all T200 performance measured while the thruster was static. Right now I try to calculate its performance while moving.
I hope that same-one succeded to bridge the gap.
I will be glode for your help
Hi @Yuval, welcome to the forum :slight_smile:
Indeed, as per the testing notes in the data file,
What’s the intended use-case/end result here?
Performance while moving is a full “space” rather than a simple relation (input → output) of values, so is difficult to measure and quantify in a meaningful way. The water can be moving at different speeds, in different directions, and with varying levels of turbidity, and can also include particulate matter, which may all have differing effects individually and together. While it would be possible to measure performance in a particular set of conditions, even measuring the conditions themselves accurately is challenging (speed isn’t too bad, water direction and turbidity are difficult, particulate matter is an additional issue). Covering the full space of conditions that people are likely to come across includes many combinations with complicated setup and measurements, so isn’t something we’ve done at this point in time.
If you’re after a transient response or similar, these are the best resources I’ve come across previously:
Hey,
you are right, this is all most impossible to measure all of the conditions. Even though, it’s very common when speaking on propellor separately (without a motor) to show the performance graph, as shown here:
I have tried to extract from your data the curve, but because of all of the tests done at rest, the advance ratio is always zero. I’m pretty sure that if you were making the test with velocity (say 1 m/s) it could be possible to extract the non-dimensional parameters curve. From there the calculation of the performance for all speeds would be easy.
I will take a look at the post.
Thanks a lot!
Advance ratio calculation relies on freestream fluid velocity, which generally requires an “open-water” type test. Our thruster performance data comes from testing in a tank, and that tank is small enough that it’s not feasible to measure fluid velocity in a way that isn’t impacted by local effects of the thruster (since quite soon after the water starts being pushed forwards, it comes around the sides and comes back in at the back).
It’s understandably much easier to get a highly consistent testing setup and rigorous measurements in a fixed tank than it is while attempting to tow an entire setup through open water at a fixed speed. It could also be possible to make a much larger tank and pump water through it at a fixed speed, but presumably the costs of installation, setup, and maintenance of that are prohibitive given the small amount of data that it would be used to generate.
Regardless, I’ll register your interest in moving-water testing data, and hopefully we’ll be able to measure some of it at some point :slight_smile:
I was looking for the same information and curve, much like Yuval was.
It appears that no one’s done the testing yet. I’ve got a tow tank and we’ve been meaning to test out a new load cell. I think I’ll corner an undergrad and together we’ll characterize it! :slight_smile:
Have there been any tests done to determine the advance coefficient for the T200 thrusters?
The thruster force/RPM curves are very helpful, but we are looking to model thrusters on the blueROV2 and it is well-known in literature that thrusters produce less thrust at non-zero forward speed and fixed RPM. The way to determine how much less thrust is called the advance coefficient. Just wondering if any data is laying around that could support a rough determination of this number
Here is a reference on the advance coefficient (page 4).
1991 Fossen and Sagatun JRC.pdf
Hi @cmarq,
I’ve moved your post here because it’s on the same topic.
This isn’t something we’ve yet had the capacity for testing - please see the discussion above.
Hi Andrew
I think I found the paper produced from this testing and wondered if any further analysis had been done on this? I am hoping to understand T200 performance at advance speeds at about 3.3 m/s so wondered if you had any data on this.
Joe
Hi Joe,
Our propeller tunnel is offline and our tow tank isn’t long enough to get sustained data at that speed. Once we get our tunnel up and running I want to characterize both the T200 and the T500.
Sorry we haven’t got the data yet!
-Drew
Hi @jjnichols01 -
It’s worth noting that 3.3 m/s is definitely faster than a T200 or T500 will move through the water, even at full speed with negligible resistance. Surface vessels propelled with thrusters are less efficient, as the nozzle causes a lot of drag - they are therefore more suited to low speed, high force applications! A more realistic top speed for either thruster is ~1 to 2 m/s…
