T500 Maximum Continuous Thrust
Following up on this,
For some extra context, in our initial development testing we did successfully run a sample set of T500s at full throttle for an hour in 27℃ water, with a 22V power supply, but there were some issues with extended-duration full-throttle tests at higher voltages (hence the warning about extended full throttle at maximum operating voltage), and we don’t have statistically significant samples for longer full-throttle durations, or for extended durations in higher water temperatures.
There is some additional context and discussion about thrust at speed in this post, if you want to know more.
