I’m having an issue with my thrusters. They work fine and provide what I believe is the documented thrust if I slowly (1500 ms to 1680 ms change in 1.5-2 seconds) apply power. If I apply the power quickly, the noise from the thruster increases in pitch and the thrust dramatically drops. I can drop back to 1500 ms and then slowly come back up to full power. I haven’t pulled the motors apart yet.
What ESC and power supply are you using with your T100? Let me know what you find inside, but I suspect the issues lies with one of those other two components.
Adam,
I’m using your current Bluerobotics ESC and a Rigid tools 18V NiCad battery.
I don’t believe that’s the issue. This sounds and feels like a mechanical issue (I’m a Sr. Aerospace Engineer with 20 years of in service support experience - not my first rodeo but it is my first experience with your product) It seems as if the prop is entering into a sustained Euiler’s vibration / rotation. Check out this vid for an example of Euiler’s rotation. Euler's Disk - YouTube
That’s a very satisfying video to watch all the way to the end- I see what you’re saying about the vibration. Our thrusters do not use ball bearings, rather plastic bushings for corrosion resistance, so this is possible if the fit is overly loose. We’ve never seen this before, but I suppose it could happen under the right combination of conditions. When you take apart the thruster, let me know if the bushing/shaft fit feels excessively loose.
Do you know what the discharge capability of the NiCd battery you’re using is? The T100 can draw up to 20-22A at full throttle (16V), and other issues can happen if your battery is not up to the task. The T100 is rated to run at a maximum of 16V, 18V is pushing it. I would recommend avoiding sustained full throttle operation at 18V, or damage may occur.
Yeah, I’m not thinking discharge capacity is an issue. I’m running the motors on the very low end. 1500 ms to 1680 ms (fwd) and those Rigid batteries are beasts. I hope to be able to break into the thrusters tomorrow and will let you know what I find.
Finally was able to open up the thruster. Found significant non-axial play in the shaft. Suspect bad bushings. Contacted customer support requesting warranty replacement.
Adam,
Received and installed the new thrusters and was thrilled. Work like a champ. No noise or reduction in thrust. During the down time, I also switched to 12 VDC SLA batteries. Just for kicks (as a comparison for thrust between the two batteries) I hooked up the original 18VDC Rigid tool nicad battery. The noise and the reduction of thrust returned at pulse widths between (I’m guessing here¯_(ツ)_/¯) 1600-1800ms.
First of all, I owe you an apology. The first thing you suspected was the power source and I “poo-poo’ed” you.
Sorry dude.
Now that that’s out of the way, What’s up? Why would a STRONG 18 VDC nicad make noise when a12VDC SLA is nice and quiet.
Sorry it took me a while to get to this! Its good to hear the new thrusters are working well for you, and interesting that you have correlated it to the battery you are using.
No problem, chasing down mysteries issues due to power can be challenging. When something isn’t getting enough power of voltage is dropping somewhere along the line, all sorts of odd things can happen. At the higher voltage, quite a bit more current was probably being drawn from the 18 V battery than the 12 V. This may have caused a dip in voltage in the NiCD pack, which could have started a drop in the ESC throttle level leading to the observed behavior. Was this a new NiCD pack? As far as I know, very few power tools still use that old technology, almost everything has converted to lithium or at least NiMH. If it was an older pack, the degradation over time can explain why it had trouble running the thruster.
