i first purchased 6 t100 thrusters and tested them all with emax simon series 30A ESC and arduino one time and the other was with raspberry pi 3 then i am trying to test them again now it beebs and vibrates like the motor can’t spin although iam running the same code and tried both micro controllers .
Logic is Correct !!
Checkout the Connections Again , Some Fault Might be there.
I connected the white wire in the middle of the ESC and the other two wires with the two ends of ESC
Hi @moataz,
Is this issue isolated to a specific thruster or ESC, or is it occurring across multiple thrusters and ESCs? If the latter, it possibly an issue with your setup somewhere. Can you please post a picture showing exactly how you have everything hooked up?
-Adam
i checked the soldering of each connector and it’s all fine
ping @adam
Is this the exact same setup you used previously without issue?
What kind of power supply are you using (current, voltage)?
-Adam
