Should I change the PID parameters?
Hi, guys! I have a question now! I want to make a rov whose frame is the same as bluerov, but it is bigger and heavier. Can I use the stablize mode or depth hold mode directly? Should I change the pid parameters?
Thank you!
If you want to have a better performance you need to tune the PID parameter. Any structural or actuation modification will need PID tuning to allow max performance.
That sounds cool!
Yes, this should work the same as the bluerov 2 if your motors are in the same arrangement. A pressure sensor like the Bar30 will be required for depth hold.
Yes and no. Yes for max performance like @patrick mentioned, no, because performance will probably be pretty good in the first place with the same gains. Play with them until you are satisfied.
OK! Thank you, Jacob! I will have a try.
