Set and forget Gopro for my BR
Do we have a consensus on which Gopro is the best for underwater recording (no tether, no communication)? Just press the record button and dive?
The Gopro 4 is often cited but it’s because we can communicate/live stream with it rigth?
thank you
Regarding the Gopro 4, yea your right. That one can be controlled and streamed pretty easy, where the later models are a little more complicated to get that done.
For set and forget, I think any model is going to work just fine as long as you can get a housing that protects it at the needed depth, and you can get the battery life you need.
In my experience you will need an external battery/power if you want it to record for more than ~40 minutes, and that requires a special housing in most cases.
Hi @Charles,
I don’t have much experience with GoPros, so don’t have a recommendation for “best for underwater recording”, but this thread is likely worth a read if you want to interface with more recent models :slight_smile:
anybody tried this one:
45m rated housing + battery for hero 5-6-7
or is willing to share their setup?
Wow - how do you do that? Is it through modifications to QGC code or some other way? Any advice much appreciated.
Link is dead unfortunately - unless its just me?
