Screws for the BlueROV2 Heavy Fairing Add-on
Hi everyone,
here in the robotics lab at Dartmouth College, we have a BlueROV2 with the heavy configuration. What are the screws for the heavy fairing add-on? I see that on the related product page they are M3 self-tapping screws, but I cannot find them where to get them (McMaster Carr for example has only #4 and #6 for a 316 SS).
In general, is there a bill of material for the screws, in case we need to buy some spare?
Thank you very much,
-Alberto
I’m not sure this will be of much use to you, but I made a McMaster list during assembly a couple months ago and like you I couldn’t find the exact wood screws, but found some that might be close enough. It won’t contain everything, just the fasteners that came in bags.
150m spool fasteners
1: M5 x 12 BHCS
McMaster# 94500A231
2: M4 x 20 BHCS
McMaster# 94500A283
3: #8 - 1/4 Phillips pan head wood screw
McMaster# 92525A805
4: #4 - 5/8 Phillips pan head wood screw
McMaster# 90184A110
5: M3 x 6 BHCS
McMaster# 94500A221
Spares fasteners (I think)
6: M4 x 16 SHCS
McMaster# 92290A154
7: M3 x 12 SHCS
McMaster# 92290A117
8: #4 - 1/2 Phillips pan head wood screw
McMaster# 99461A286
9: M3 x 3/8(or ~10mm) Self tapping flat head phillips wood screw
McMaster# 90198A105 (McMaster is smaller at .112 vs BR .116)
10: #8 - 18 Phillips pan head wood screw
McMaster# 90184A236
ROV fasteners
(duplicates removed)
11: M3 x 16 SHCS
McMaster# 92290A120
12: #4 - 3/4 Phillips pan head wood screw
McMaster# 90184A111 (McMaster is smaller at .112 vs BR .116)
13: M4 x 18 SHCS
McMaster# 92290A161
14: M5 x 16 BHCS
McMaster# 94500A232
ping @adam
Hi @quattrinili,
Yes, the heavy fairing screws are the same as the thruster nozzle screws, metric self tapping M3 x 12 mm. They are stainless 316 with a Phillips drive countersunk head. You can find similar screws here, or if you contact us we can send you a couple.
-Adam
Thank you @adam, I tried the screws from uxcell, however one of them broke – I guess they have a lower strength compared to what you provide. I will contact you then to receive some screws and get an extra fairing.
