I think we are using an older ‘r1 power sense module’ see picture;
The setting for which i cant find in qground control parameters - can i just select r2 in parameters?
Hi @triton,
We still have the parameters for the R1 here: Power Sense Module (PSM) Installation: R1 PSM (16 mm long PCB)
They are mostly the same except for the Amps per Volt setting. We had to use a different current sensing chip for the R2.
