Python Library 0.1.1 PWM
Hi all,
I just wanted to highlight the point to the community.
I have just upgraded the lib to version 0.1.1 via command — pip install bluerobotics-navigator
Code written to control pwm channel crashed because import PwmChannel was impossible.
Calling the full list of voices of the library “PwmChannel” does not compare.
Lower versions works fine.
Hi @FraSec -
What version of BlueOS are you using? Or Linux if you’re running on your own machine?
Linux raspberry 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
