Module 'bluerobotics_navigator' has no attribute 'set_pwm_enable'
I am trying to follow some examples to make my own code in python and I am getting this error when trying to use the PWM channels.
Any clue on how to solve this?
Have a nice day!
UPDATE:
I did not mention that this problem occurs when I am using the Jupyter extension. I just ran the code using the terminal and it works fine.
Hey @Alex_UJI1,
A newer version of the Jupyter Extension is available. Could you try updating it?
Alternatively, you can quickly work around this by running the following command in Jupyter:
!pip install --user bluerobotics-navigator
This will reinstall with latest version available for the library.
Thanks!,
For some reason, running the command did not worked, but updating Jupyter solved the issue.
Have a nice day
