Problem with wifi on BlueOS
I have some issue with wifi connection . I select wifi , insert the properly password but when restart the os it lost the wifi . How i can solve it ?
Hi @virtualrobotix -
We’re not able to recreate that issue! What version of BlueOS are you using? You’re setting up the WiFi credentials from the icon in the upper right of the BlueOS interface?
Hi ,
thanks for your reply , i use last version available the beta … i click on icon up on the right , choose right wifi , insert the password when request then it’s properly connected … and optain right ip . When reboot … i need to connect by lan … at 192.168.2.2 and set again properly wifi and properly password . The Blueos don’t store the password .
The other option instead like for example the serial bridge is properly save and work fine . Only some time i need to delete and re create because the serial stop to porperly work .
If i downgrade from latest beta at stable version is not possibile to use wifi .
I’m using cm4 module … connectect to AMA4 to my autopilot. But the wifi are indipendent to autopilot.
I have another question the port 14001 work only on last revision of os in previous it don’t work .
Do you use other port in previous version of blueOS ?
That is the reason because i’m using beta and not last stable .
