When I tried to use BlueOS this morning, I have connected the groundstation wifi and successfully connect the qgroundcontrol. But I can’t connect the BlueOS to my boat. I think the reason is I didn’t connect the wifi on my BlueOS but I can’t find wifi since I used my blueboat. I can connect the BlueOS without network and everything works well last week but right now I can’t click anything on BlueOS and I can’t find any wifi even for my private hotspot. I am using 1.3.1.0 version. Is there anything that I can change? Thanks for your time.
Hello,I meet the same problem about WiFi connection.Have you find what’s wrong or how to slove the problem? Please give me some suggestions ,thank you very much
I am using a Raspberry Pi 4B with the system blueOS 1.4.1 pi5 version. My system is completely unable to connect to Wi-Fi, as its Wi-Fi functionality is disabled, and I cannot enable it using commands. What is the issue, and what should I do? These images may help with the analysis.Thank you for helping me
Hi @link4 -
I’d recommend flashing your SD card with 1.4.2 stable - if the issue doesn’t go away, your raspberry pi may be damaged?
