WiFi Connection Issues on BlueOS with ROV
Hello, I am facing an issue with the WiFi connectivity on BlueOS. About three months ago, I was testing the ROV, and everything was working fine. However, when I turned on the ROV a couple of days ago and tried to connect to WiFi, I encountered problems.
Could anyone provide insights or possible solutions to fix this issue? Any suggestions or troubleshooting tips would be greatly appreciated.
Thanks in advance!
Hi @Sakthivelj,
Hmm, not sure what’s causing that, although in your screenshot you’re currently running 1.1 despite having 1.2.5 installed, so perhaps it has reverted to the factory image and is experiencing some old issues or bugs that were present in 1.1.
I’d recommend switching back to 1.2.5, and then updating bootstrap if there’s the option to do so (the old bootstrap image had an issue with reverting back to the factory-installed image overly frequently, so updating it should help prevent accidentally ending up in 1.1 again in future).
