jwalser
(Jacob)
April 5, 2019, 12:36pm
21
Can you send us a picture of how everything is hooked up?
This is the only documentation on it: Redirecting... .
jjabraham:
hanks to your help, my ROV is leveled but every now and then, it malfunctions and the attitude indicator goes in all kinds of directions. BTW my depth sensor is also malfunctioning too. i tried rebooting it and i re imaged the pi but i’m still getting the same results. i have to re level the horizon to get it back in shape but it malfunctions again after a couple of minutes. what should i do. is my pixhawk defective?
This is not normal, the attitude messing up may be a result of the pressure sensor malfunctioning. Can you take a picture of everything put togetehr?
jjabraham
(Jay Abraham)
April 5, 2019, 3:29pm
22
will do, when get access to the ROV at my schools lab, i send some pics
jjabraham
(Jay Abraham)
April 7, 2019, 7:54pm
23
my bad i post the pics of the wiring to the wrong post. here is a link
jwalser
(Jacob)
April 8, 2019, 2:43pm
24
You’ve made the signal wires for the pressure sensor much too long. I2C bus is sensitive to wire length, the 12" lead on the sensor is already about as long as it can possibly be and still work correctly. You should try to connect the pressure sensor directly to the pixhawk i2c port.
jjabraham
(Jay Abraham)
April 8, 2019, 10:33pm
25
This is wonderful. Thank you soooo much!!! Should i buy a new pressure sensor in order to fix the problem
