Prearm: Battery 1 low capacity failsafe
Hello guys!
Have any of you experienced “Prearm: Battery 1 low capacity failsafe” problem?
What is the fix?
The battery is definitely ok, tried to reboot all pc’s, re-connect or swap batteries. No changes.
Thank you for support in advance.
Can you check what your BATT_ARM_MAH and BATT_LOW_MAH parameters are set to?
I updated QGC to version 4.1.1 and it worked. thank
