Hi all,
During testing of my BR2, I have noticed that if I run a battery for a second dive, that qgc shows battery status as 100% again. Even though I had run the batt down to 60% on first dive.
Any thoughts on this small issue? All help accepted
Hi all,
I’m guessing the percent status might be based on mAh used and not the battery’s voltage. A more accurate ( and in my opinion useful ) measurement to display is the battery’s voltage. That’s what I do and with my 4s 10Ah LiPo battery, I run the ROV until the voltage is around 13 vdc (lowest recommended voltage is 12.8 vdc). Hope this helps.
I will look into changing the way this is done. We could discuss approaches on gitter.
-Jacob
